Corncrete sectional garage ?
26 Aug 2013
Hi guys
This is my first main post, anyway 3 years ago I bought a new liggit concrete sectional garage that was delivered and erected by liggit them selfs as the garage was too big for the local liggit supplier to install at 18' 6" long x 18' 3" wide and std garage hight.
anyway since I bought it and without any problems I have decided on changing my car for a 4x4 and the hight of the 4x4 is 6'6" high which is the same hight as the doors and trusses :eek:
the doors are not a problem as I have a mate who is a joiner who said he can sort them but the trusses are steel and its only the front trusse that I have a problem with and I am thinking of altering it by welding a piece of box section steel the same box section that is originally used on the trusse across the centre of the trusse which means it will be welded to all the strengthening parts keeping the strength there then cut the bottom part of the trusse out allowing me to drive the 4x4 in and jack up aswell if needed.
can this be done cheers graham.
Odd first post, but heyho. At first I thought "spambot", then I noticed you wrote Liggit 3 times, the company name is Lidget isn't it? ;)
Anyhow, I'd contact them and ask, surely it's something within the company's remit. I like bitslice's idea of raising the roof, maybe it's possible to just raise the door a bit, some pics or a link would help
Thanks guys I will dig the paper work out and go and see them as they are literelly just up the road from me.
the problem with raising the roof is that I would have to have planning permission or something as the roof will be over the std hight regulation all I want to do is to keep to the same externally but raise it internally by altering the trusse in question :)
