Correct BIOS Settings For 'CPU Feature' (IP35-PRO)
15 Oct 2007
Bedfordshire, UK.
What are the correct settings to have with in the CPU Feature tab in Advanced BIOS Features for the ABIT IP35-Pro mobo for a stable Overclock?. Currently i have:
Thermal Control Disabled
Limit CPUID MaxVal Disabled
C1E Function Disabled
Execute Disable Bit Disabled
Virtulisation Technology Disabled
EIST Function Disabled
Ideally what should they be set to?
Ok so i should only have EIST & Execute Disable Bit enabled? What does 'Virtulisation Technology' actually do?
"Virtualisation Technology" enables the bits of the processor which allow it to natively support running Virtual PCs via VirtualBox, VMWare or Microsoft VirtualPC - which allows you to run a completely separate/standalone operating system "on top" of your active operating system - great for testing out various software configurations.
If you don't need to use Virtual Machines - then it won't really matter.
