I have just build a PC with the OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit
Just went into the BIOS and went under 'Advanced Mode' - 'Ai Tweaker'.
At the top it says 'Target DRAM Speed : 1333MHz', and underneath the 'Memory Frequency' option is set to Auto.
Shouldn't it be set to 1600MHz? Which is an option that I can set instead of Auto.
(Just tried setting it as 1600MHz, and all seems to run fine its just in the program Smart Doctor the RAM temperature is now blank with no readings, whereas before it showed the temperature of it, so it's as if it doesn't recognize it's there anymore ??)
Any help would be much appreciated. Thanks.
