- 4 Oct 2005
- Herefordshire
Hey guys im after some advice.
These are the fittings I will be using for my wc build.
Monsoon Chain Gun Fitting 1/2” x 3/4” Multi Pack – Red
https://www.overclockers.co.uk/showproduct.php?prodid=WC-198-MO
What is the correct size tubing I should be ordering for the above fittings please.
I ordered a test piece of tubing , and it doesn't look like it fits correctly.
Thank you
Thank you
