Correct speed?
18 Jan 2006
Hi all..
Running a 64/4000 skt 939 on a asus a8n-e mobo.Recently the pc's been running slow and,as i only had 1g of ddr400 memory thought maybe another gig would be a good upgrade.I managed to get hold of 2x512 ddr4 corsair pro.I now have 2x512 corsair pro and 2x512 corsair value select fitted.
After using my pc for over a week now i haven't noticed a great improvement,if any, from before.I've downloaded cpu-z and the following made me wonder??
frequency -100.7 mhz
fsb.dram-cpu24
Is the frequency correct??
cpu at stock settings btw
thanks all
The Halk said:
I'm afraid that's the way it is.
DDR needs 2 modules, and generally won't work with 4.
Huh?
Four sticks will run fine at 2T on 939 boards.
Dude go into your BIOS and change the RAM divider to 1:1. That should bring it upto speed.
Cob said:
Huh?
Didn't realise it'd do it at 2T on 939.
In any case, 4 sticks won't do the same timings as 2 sticks.
2T will come under Command Rate in the memory timings section.
IIRC the RAM divider options were 200 (1:1), 166, 133 and 100mhz. But they may have been 400 (1:1), 333, 266 and 200.
It's been a while.
Sorry to be noob
i can find memclock index value which makes sense with what you are saying-is this the one?
currently is at 200 but will go to 400 etc-not yet tried it though.
Yip 200 sounds right for your memory only running at 100 in CPU-Z.
Set it to 400 and cross your fingers.
I haven't tried 400 yet but just went into lotro online to test.Usually when i go into a large town/busy area my hdd goes crazy loading and then throws me to the desktop,anyway,it did the same!!
Maybe its cause i have a 8800gtx with an out of date setup??
