we use a SOE + CITRIX enviroment each PC has Windows XP and each user has a domain account. Each user has a roaming profile path in AD eg \\servername\leeds$ and a tsprofile path eg \\servername\leeds$\tsprofile which is fine but we are experiencing problems with corrupt profiles
When logging in after the ctrl alt del screen it hangs on loading personal settings or will reboot it self. You have to get the user to boot the pc into safe mode with networking and as quickly as possible delete the corrupt local profile as you lose connection. You also have to delete the roaming profile from the server because if he goes onto another pc it will corrupt that as well
Has anyone encountered this before? i beleive its delayed write failures causing the issue
