Twice in as many weeks I have received the dreaded
"Windows XP could not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
message. Each time I have been unable to use the 'recover' option available from booting the windows xp disk because, once in the recovery mode command prompt the machine has simply failed to recognise that any disk is present.
The first time I managed to boot into linux (dual boot machine) and copy a few registry files around and this at least let me boot into windows but all the installed software was either flaky or just wouldn't run.
I am, this very minute, using the 'repair' option provided as part of the windows install process and ......
windows is at least booting this time, but wants another 39 mins to finish the install (I hope it's just installing over the top of the original install)
(25 mins later)
it boots but first thing that happens is AVG tells me it has failed to recognise my license number. Touch wood, everything else I have tried so far seems to be working
any ideas what may be causing the corruption in the first place could a piece of hardware be on it's way out maybe?
(25 mins later)
