Corsa 08, VIN, Chassis or frame number where is it?
19 Jun 2009
I'm applying for a new V5 on a 08 Vauxhall Corsa, the V5 form is asking for a VIN, Chassis or frame number.
I have looked in the engine bay and don't see any plate, there is however this code below the left of front windscreen.
Does anyone know what the number below is and can it be used to apply for new V5.
Thanks for any help
Jason
Is that in a little window visable through the windscreen? I think it's actually fixed the the base of the dash. If so, thats the VIN.
Any issues posting the VIN online? I'd remove the pic now you've had an answer just in case, or is that a stupid idea?
Thanks for everyone's input, it's very much appreciated.
Yes it's the number that's in the bottom of the window, at the bottom of dash, the part that's flush with overlapping glass, there is a cut out and that number is showing.
On early Vectra's it use to be strongly attached to the corner of dash, but on modern Vauxhall's they appear to do this instead.
One final noob question. Is the '0' between the W and L a Zero or is it an alphabet 'O'.
Thanks Jason.
