Pretty much, you can buy specific blanking plates for them which are less fiddly, bit of a pain with the angle of the hole you need to cover as the coin will move as soon as you let go to tighten the pipe back up
, quick wipe around the edges and a lil dab of araldite on either end of the coin did the trick for me
Mine had started to be a lil hesitant for awhile before gradually getting worse, blanked off the EGR and ran great afterwards, garage even commented on how clean it ran for a diesel when it went in for its MOT, best 2p I ever spent
Edit:
Had a quick look on AOC as I was certain someone had asked about a Corsa C 1.7 DTI EGR blank before:
http://www.astraownersclub.com/vb/showthread.php/726190-1-7DTi-EGR-Blanking!
Edit:
