- 11 Mar 2013
- West Midlands, UK
Need help with this one guys. I've got a 54 plate corsa life 1.2. Knew there were a few problems with it when I brought it but for the price I got it at it still seemed worth it.
Anyway, just before winter kicked in I was getting the wet foot wells, so I did my homework, found out where the water could be coming in and did what I could... Long story short I had the carpet out for a couple of weeks whilst that dried out, plugged holes and changed the heater matrix (as there was very little heat coming out and coolant was being lost).
She didn't leak for the two weeks the carpets were out and so the carpet went back in and for a few months she remained dry.
The weekend just gone however, I got in and noticed a wet patch in the drivers foot well, squeezed it with my foot and low and behold there's a couple inch of water down there again! I've checked the coolant and that's looking pretty dried out which obviously points to heater matrix again but I'm still getting abundance of heat from the blowers.
There hasn't been any rain recent (especially enough to warrant the amount of water I have in the car)
One more thing that points to it being the water system itself is that since the puddle arrived, the car has actually been running a lot smoother, its usually a bit juddery on pull off but I used to put this down to the gearbox as I have another one to put in it soon due to the current one being a bit knackered lol So now I'm thinking maybe it was some sort of lock in the system.
Is there anything I can try before I end up taking her tho the garage for a pressure test?
