Corsa Coolant Capacity
Just had a quick look and it seems it's 5.9L just keep filling it up till it's on the max bleed it and top up and after a little drive check again and see it's still on max.
Cheers mate, just wanted to find out as I need to get some antifreeze so wanted to make sure I buy enough in one go for the mixture. Not my car and it's been sat up for about 6 months, being taken for it first drive later all being well with the cooling system.
Ah sounds good make sure you get the right ratio so it won't freeze. Good luck with the car!
