Corsair 1600i power cable
26 Jun 2009
London
I recently got a Corsair 1600i replacement for my blown Corsair 1500i PSU. Unfortunately it came with a European plug. I still have my original 1500i plug. They both have the same connector (C19). Just wanted to make sure I could use the old 1500i power cord with my new 1600i?
thanks
Yep will work fine. I got an EU plug with mine so used my HX1200i PSU cable (which my AXi 1600w replaced) until UK plug replacement arrived. Only thing I did notice was the AX1600i cable was of thicker gauge compared to the HX1200i cable I used until I received the replacement.
Cheers thanks, I spoke to someone else who had the same issue and the old plug works fine. Just wanted to be super careful as PSUs are so scarce.
