Corsair 16gb
24 Jun 2004
Carnoustie
Hi ,im quite a bit outta of the game regarding Memory lately,I have 16 gb[2x8] of corsair 3600 18.19.19.39
im stuggling to find the same ,does the timings make much of a difference
Im looking to go up to 32 now
I just did the same, stuck with identical LPX 3600 cl18 to be safe, and paired the same on mobo. You should be able to find what you need as I bought second kit a couple of weeks back?
Ah ive just noticed [doh] Ive a rog strix z370-i mobo
This has only two slots available
Ok another quick one ,would it be a better idea to sell the above memory and purchase new 32 gig ?
or is it just a cost incur for very little upgrade .
Thanks
Thanks
If you need more than 16gb then yes it's worth it.
