Corsair 250D owner question...
18 Jan 2007
Eastbourne, East Sussex
Can't seem to find any info anywhere about how tall the GPU can be in this case? I've just got my MSI GTX 970 Gaming card which compared to my previous cards and the ones used in reviews is quite a bit taller.
I want to know if it will fit in with the PCI-E connectors connected too, I don't plan on using the 5.25" bay so that doesn't matter if it would need to be removed to accommodate.
Moving from a Prodigy to this. Going to be putting a H100i, the GPU above and a 200mm in the front, any word of warning?
Cheers chaps!
