Corsair 2GB DDR XMS3200 - CAS2 or CAS3?
17 Mar 2006
Quick question....are the CAS2 worth the extra £30? I really only wanted to spend about £140ish. And would either of these be a good choice to replace my 2x512 Ballistix with?
No overclocking, I just wanted to run 2GB but thought this would be better than running 4x512 - especially as no-one seems to have the Ballistix in stock at the moment so I'd have to mix and match....
Everything in my machine is running at stock speeds.
just go will cas3 then, 2gb from 1gb in memory will be very good performance increase anyway ;)
I hve this memory, runs at CAS 2, just have to manually enter in CAS 2 in the BIOS (leave on auto and it sets at CAS 3) Make sure you're not running faster than 200mhz
