Corsair 300R - In stock now!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
The long wait is over, the Corsair 300R case is here. All back orders are shipping now.
Corsair Carbide 300R Mid Tower Case - Black @ £59.99 inc VAT
The Carbide Series™ 300R is a compact expression of the Corsair philosophy: great systems begin with a great case. Open the easy-access side panel to find a builder-friendly design with three tool-free optical drive bays and four tool-free hard drive bays with integrated 2.5” SSD compatibility. There’s room for extra-long graphics cards, and the matte black interior really shows off your gear. Finish off your build with a cable routing system that keeps wires and cables out of sight and out of the airflow path for a clean, uncluttered look.
The 300R keeps your hardware cool with amazing airflow, including a 140mm front intake fan and a 120mm rear exhaust fan. There’s room to add five additional fans, including dual side-panel fan locations that can deliver cool air directly to your graphics cards. And, the dust filters are removable for easy maintenance. Features like these make the Corsair Carbide Series 300R the foundation of your next great system.
- Room for graphics cards up to 450mm long
- USB 3.0 front panel connectors
- Built-in compatibility for SSDs in the four hard drive bays gives you the flexibility you need
- Keep your system cool with up to 7 fan mount locations
- Easily accessible dust filters keep the cool air flowing over your valuable components
- Install or upgrade your CPU heatsink quickly with the easy-access backplate cutout
- Optimize airflow and keep your system neat and tidy using the intelligent cable management system
- Drive Bays: 3 x 5.25" Drive Bays and 4 x 3.5"/2.5" Drive Bays
- Cooling: 1 x 140mm intake fan and 1 x 120mm exhaust fan
- Expansion Slots: 7
- Motherboard Support: ATX & mATX
- Front I/O: 2 x USB3.0 and 2 x Audio
- Dimensions: 19.1" x 8.3" x 17.7"
Only £59.99 inc VAT.
ORDER NOW
Nice ;D
What fans are optional for the top? None?
2x 120mm or 2x 140mm in the top.
2x 120mm or 2x 140mm in the front.
There is a video review by TTL which is worth watching (no idea if it is allowed to be posted here or not though).
Overall I am pretty impressed with this case, great job Corsair.
Stoner81.
