Corsair 300R USB 3.0
25 Jun 2011
Herts, UK
Do the two front panel USB 3.0 ports connect to the motherboard separately (i.e. does it require a motherboard with two internal 20-pin headers) or do they both connect with the same header? Thanks.
After a quick google for a few reviews (always a great source of information for this sort of thing) it appears it is a single 20-Pin cable for both front mounted USB3.0 connectors.
