Corsair 350D in stock!!!!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys!
Corsair 350D Micro ATX cases in stock now! First in the UK with stock!
Corsair Obsidian 350D Windowed Micro ATX Case - Black @ £94.99 inc VAT
The Obsidian Series 350D Micro ATX PC case is designed for building compact high-performance systems with Micro ATX and Mini ITX motherboards. The compact size is ideal if space is limited, but there’s plenty of room inside for liquid CPU cooling, dual hard drives, dual SSDs, SLI/Cross Fire ready.
Like all Obsidian cases, the 350D is designed for fast and neat builds, with tool-free access and drive installation. Smart features like a native 2.5” SSD cage make the most of its small size, and the cooling-focused interior has five fan mounting points, with room for two 240mm radiators.
- Windowed Side Panel
- Micro ATX and Mini ITX motherboard compatible
- Brushed Aluminum Front Panel
- SLI / Cross Fire ready
- Five Expansion Slots
- Two 2.5", two 3.5", and two 5.25" tool free drive bays.
- Modular 2.5" SSD cage
- Front 140mm and rear 120mm cooling fans. Room for up to five fans total.
- Direct Airflow Path from front cooling fan to GPUs.
- Maximum ATX PSU length 180mm
- Maximum GPU length 380mm
- Maximum CPU Cooler Height 160mm
- Room for two 240mm radiators (top, front)
- Dual USB 3.0 ports
- Dimensions: 450mm x 210mm x 440mm
- 2 Year Warranty
Only £94.99 inc VAT.
ORDER NOW
Corsair Obsidian 350D Micro ATX Case - Black @ £84.95 inc VAT
- 2 Year Warranty
Only £84.95 inc VAT.
ORDER NOW
This case cannot take ATX board? Only Micro ATX board! big disappointed. Can ocuk please sort out motherboard Micro ATX on their site please as I cannot find there
I love this case exspeciaslly beautiful windowed but I wish Corsair do the same like this for ATX board which it rather annoyed!
Can ocuk confirmed to me if this board are good for overclock and does this silver arrow will fit in this case? If yes, will ordered on Monday with 5% to get the price down to £277.47
Bulldog147, you should move to watercooling for extreme overclocking. RJKONEILL is our expert, I'm sure he will help you!
Also the M3 board is average at overclocking, get the sniper it's a better overclocker.
*snip*
Don't you already have a regular Silver Arrow? The SB-E will be maybe 1c better if that and isn't worth the expense if you already have the original.
I am no expert on watercooling as this isn't an easy job to do. I always wanted to do watercooling one day. So, Rjk can get in touch with me and discuss with it.
HI I use these for a 4.6 out the box (I3570K) .
http://www.overclockers.co.uk/showproduct.php?prodid=MB-516-AS&groupid=701&catid=5&subcat=2261
http://www.overclockers.co.uk/showproduct.php?prodid=HS-015-CS&groupid=701&catid=2330&subcat=2262
Should fit this case,
looks like the main pic and its not rocket science too fit .;)
