Corsair 350D vs Fractal Design Define R4
17 May 2012
I'm currently using the Define R4, but I want to move down to the Corsair 350D. Has anyone used both or have images of the two together? I want to know how smaller the 350D will be. The main point of me switching to mATX is to save space.
I don't have any pics I'm afraid but I love my 350d. Ive loads of gear in it and as a system its never skipped a beat.
Small footprint on your desktop, good build quality and looks good as well.
I'm currently saving up for a system upgrade and I'm going to use the 450d I think.
In the past ive had an 800d and 700d, you could say I'm a fan of Corsair cases
There are a few images on google if you search "define r4 vs 350D" doesnt look that much smaller, from the front anyway.
have you compared the sizes. you might not be saving much space
corsair Dimensions: 450mm x 210mm x 440mm
fractal Case dimensions (WxHxD): 232 x 464 x 523mm
there no much in the width and height and it will just the depth you will notice
