I imagine this is the '600T' mini that was speculated
Corsair 350D Specifications:
2 – 5.25″ Bays
2 – 3.5″ Bays
2 – 2.5″ Bays
2 USB 3.0 Front Ports
3.5MM Audio jacks on front panel
1 – 120MM Rear Fan
1 – 140MM Front Fan
Dimensions : 17.7″ x 8.3″ x 17.3″
Weight : 13.3 lbs.
Additional information:
Brushed Aluminum Front Panel
SLI / Cross Fire ready
Modular 2.5″ SSD cage
Front 140mm and rear 120mm cooling fans. Room for up to five fans total.
Direct Airflow Path from front cooling fan to GPUs.
Maximum ATX PSU length 180mm
Maximum GPU length 380mm
Maximum CPU Cooler Height 160mm
Room for two 240mm radiators (top, front)
Apparently priced at $99.99, so around £79?
2 – 5.25″ Bays
2 – 3.5″ Bays
2 – 2.5″ Bays
1 – 120MM Rear Fan
1 – 140MM Front Fan
Weight : 13.3 lbs.
