Hello,
As title says I currently have a Corsair 4000D Airflow and considering replacing the fans for it.
The case came with 1 x 120mm rear fan and 1 x 120mm front fan.
Currently I have the following setup
- 2 x 120mm fans in the front, 1 that came with the case and 1 x 120mm fan that I had left over from a previous AIO - pulling air in
- 1 x rear 120mm fan that came with the case - Exhaust
- EK Water Blocks EK-AIO 240 Basic All In One CPU Water Cooler with 2 x Noctua NF-P12 Redux 1300rpm PWM Fan - 120mm - Exhaust. This is mounted along the top of the case.
My question is, does anyone have any suggestions for what fans to get and the best fan setup to use (exhaust\pull config).
There seems to be so many types of fans to get depending on setup and use etc
Thanks
Thanks
