- 26 Dec 2013
- 404 Not Found
I think I am going towards the idea of using the 450D for my next build but I need a couple of sizes to see if my water setup will work.
I need a measurement from the front (inside the case) to the start of the motherboard try. And also the height from underneath the drive bays to the bracket.
My reasons for this is I would like to mount my rad AX240 up front and possible mount my reservoir/pump onto that bracket behind the drive cage.
Also, is it possible to fit a 360 rad up top and still use the drive bays?
