Corsair 460x with six fans - Noisy!
16 Apr 2004
Shropshire
Will that work with those fans, not sure if they are PWM?
Is there a step down reducer thing in the box to reduce voltage/speed?
They're three pin so I assume they aren't PWM. No step down in the box.
I thought, maybe wrongly, that the NZXT could adapt the voltage/wattage supplied to each fan and therefor control the speed that they ran. Am I wrong about that then?
EDIT - (Note: PWM fans on GRID+ V2 will still be controlled via voltage not PWM duty)
Looks like the GRID+ V2 does use voltage to control speed so I should be fine.
