Corsair 460x
6 Apr 2009
Liverpool
Just wondered if any of you have this case if so how did you get on with the cable management especially around the 3 ssd brackets how did you get your power to all 3 with them being so close to the side panel thanks...
I've got this case and have to say that the cable management is a bit of a pain, it's definitely not easy. I've only got one SSD and one HDD in mine so what I did was remove the SSD bracket on the back to give me more space for cable routing and just used the cage at the front of the case. Of course this is only viable if you're not using more than two hard drives. I'd suggest putting the PSU in early and cabling it up. Once you've got the motherboard installed it can be quite hard to feed cables through some of the grommets, particularly the ones at the top of the case.
It wasnt bad in the end just going to order a few sata power splitters whith separate wires rather than use the ones with power supply that have 3 on each cable....just go to figure out why my h100i pipes are pushed up to top off case stopping me getting 2 fans in think i need to the block of the cpu and turn it around..thanks for the input.
