Corsair 540, 2 x 980 GT SLI. Room for Xonar soundcard?
3 Jan 2005
Hi all
As per title,
I am building a new rig:
2 x Gigabyte GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card
1 x Asus Rampage V Extreme Intel X99 (Socket 2011) DDR EATX Motherboard
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW)
Am I going to have enough room to fit my Asus Xonar Essence STX card from my old machine?
I remember with my old build, once I added another gfx card, there was not enough clearance for the card.
Many thanks in advance as usual
Hi all
As per title,
PCI-E x1 hardware will work in PCI-E x16 slots as well!
Just install the STX into the bottom PCI-E x16 slot and you are set, and should be far enough away from your second graphic card:
http://www.asus.com/uk/Motherboards/RAMPAGE_V_EXTREME/
...so you just install the STX into the red PCI-E x16 slot at the very bottom.
