So I decided when I order this case that I am going to remove the stock fans and replace them with Corsair Air Series AF140's Red Led, so that would be x1 rear and x2 front.
My main question then is as I also decided to go with the H100i which would be positioned at the top, could I fit another 2 of the 140mm AF140mm fans at the top?
See I decided to put a bit more money into this for cooling and looks but as you may know from my recent posts have never done water cooling or used an AIO liquid cooler. Therefore I don't know how I could add 2 extra AF140 fans at the top? Would I just screw them into the case like normal and the H100i sits underneath them, or do I put the fans directly onto the H100i, does it come with fittings for extra fans etc?
Simply put, I want the H100i at the top of the case, but I also want two of those AF140 led fans at the very top to add some lighting and better cooling but I don't want to order more fans then I need if it cannot be done.
Does anyone have any experience with this case or type of setup?
Hope this is clear thanks.
