Corsair 540
According to the description on the ocuk shop blurb for the case you can.
Ideal for Advanced Air Cooling and Water Cooling
You can mount up to six 120mm or five 140mm fans, or install a 240mm or 280mm top radiator and a 240mm, 280mm, or even 360mm radiator on the front panel. Corsair’s innovative cable routing system gives you more options for hiding pumps and tubing out of the way.
