corsair 540
16 Jan 2015
hi im looking at getting the 540 but i was wondering if its got space to an led strip inside the window panel? and if so what one would fit best?
Just had a check of my 540, and there are strips of metal that are large enough to fit led strips onto them, I would say that most 300mm led strips would be able to fit, if it is directly above and below the window that you are looking for
Its not the best case for LED strips but there are a few options for placing them... ended up turning mine off when the novelty wore off after about 2 days.
