Corsair 550D - How to install bottom fans ?
20 Aug 2006
mounting points don't seem to have any threads ? you seem to need rubber threaded mounting points like used on the rear
mine didn't come with any though
any ideas please ?
thanks, Buckster.
King Damager - aha - thanks - I'd forgotten about rubber grommets they'd do the trick ta
will order some in - in meantime I'll check to see if any should be included - seems odd to have fan positions you can't use out of the box so to speak
cheers
Mine came with enough spare screws to mount four addition fans in the top/side/bottom positions. It also came with different screws for mounting fans to the rear of the drive bays.
