Corsair 600t build
23 Sep 2007
Thought I would share some pics of my new 600t build. I moved my PC to this case from a Coolermaster stacker 832.
The case is very easy to build in and it was done in a couple of hours.
Old PC. (Warning not a good sight)
New 600t build.
Still have a couple of cables to fit, move the DVD drive and tie the wriing at the back. Nearly there.
Thanks.
Glad you finally got your case, shaf :)
Hope you're happy with it mate as I've heard some good things from other people that have got the 600T and I've seen some pretty nice builds showing up online recently (like the one shown below).
What are your own thoughts on the case, shaf?...in terms of build quality etc?
Hi diverse180,
Thanks for the comments.
Yes I have been impressed with the case and the build quality. Although it is big for a midi tower. My CM 832 was a big case and I would have thought would dwarf the 600t, but this is not the case, smaller yes but not by much.
There is some plastic elements to it but this does not bother me really. Overall, building in it was great and enjoyable. Still need to sort out the cabling at the back. Would have liked there to be a few more cable tie holes at the back thouigh.
There is hardly any documentation with it - you might think it's not necessary but I could not figure out the fan controller connectors as they were female connectors. quick to visit to the Corsair website and found these were just protective caps and slide off. :)
