Just finished my first watercooled PC, went with the corsair 600t.
With regards the the watercooling blocks I went with the EK FC blocks, I wasn't sure about them like most people but when you get to feel them they are quality parts, plus I think they look good with the full cover backplates. Anyway here is my spec,
I7 3770K @ 4.5 ghz
GTX 680 SLI
Asus Z77 Deluxe MB
16gb vengeance RAM
Corsair 600t White
XFX 850 pro PSU
2 x Corsair GS 120 gb in RAID 0
2 x 3gb Seagate Barracuda
Litewon Blu Ray
Corsair quiet edition fans for the roof and rear.
For the watercooling
Alphacool 240 rad
Phobya Xtreme 200
EK compression fittings
1/2" hose
XSPC pump/bay combo
Ran some benches including Prime for 12 hours and a looped 3dmark 11 for GPU / CPU stressing for an hour and max temps were CPU 53C / GPU 51C.
If you are looking at a similar build I would say that the 600t is not the greatest case for watercooling case, you are quite limited in the rads you can use, but you can still get some good results if you try. If you are wondering where the SSDs are I put a pair of them in a Silverstone drive bay converter which can house a 3.5" or a couple of 2.5" SSDs.
appreciate any feedback you can give. Thanks - TC
I7 3770K @ 4.5 ghz
GTX 680 SLI
Asus Z77 Deluxe MB
16gb vengeance RAM
Corsair 600t White
XFX 850 pro PSU
Litewon Blu Ray
Alphacool 240 rad
Phobya Xtreme 200
1/2" hose
XSPC pump/bay combo
