Corsair 600T Windowed Side Panel
28 Nov 2003
Manchester, UK
I have a black Corsair 600T which is still in very good nic. The black version only came with the mesh side panel in the box whereas the white versions came with the window side panel.
Can anyone find me a place that sells the windowed side panel. My google skills fail me.
contact corsair directly they might send you one out for free (sent me a free replacement grill for nothing after making a bad cut in it!)
be warned though it creaks when it gets warm (honestly its not a huge issue I don't even notice it anymore especially after loosening up some of the screws holding it in)
I'd get in touch with Greybeard here, he's a Corsair rep and has helped me out in the past with side panels/grills etc, for the 600T.
If you go onto the case forum http://forums.overclockers.co.uk/showthread.php?t=18571712&page=7
Mine is on there.i made it myself 10mm perspex i think the size i got was 600x500
and it only cost me £32. i know MNPC Tech do a lot more better then mine. but no way was i going to pay £160 INC shipping just for that
Neither would I pay anything near that for a side panel. Just had a look at yours, really good job there :) you fancy making me one for £32? :D
No sorry lol
It was a pain in the arse to make. All you need is a jigsaw and a 10 mm drill bit for the holes. And sand paper. Using the jigsaw at first was hard.i went abit to fast and the plastic melted back. Luckly I had enough size
He's been in touch with me, and it looks like a windowed side panel shall be on its way to me very soon. That really wasn't what I expected, what an absolute legend! :)
No sorry lol
I don't need it now, see above :P
Glad I could help :) If you need anything else from us, you are always welcome to contact me directly.
At last the search for a side panel is over. A brand spanking new windowed side panel received today, was shipped over all the way from America! Will be sticking to Corsair in future for cases, thanks again for sorting that out Greybeard :)
