Corsair 600T
want want want....Just need pay day to roll around...white case looks mighty fine, but think I'll still go for the black one. Nice build with the Green LEDs in though.
Looking good, get them cables a bit tidier though. such good cable management potential in that case.
Yup, just a quick build as I had some stuff to get done, will get tidying over the weekend, was rather simple to keep it neat early on. I do have a few strays I need to sort out :p
Green LED's are from my GTX 480 SOC, they do look awesome :)
I really wouldn't want a window, how come the black can have a solid side piece but the white has the geek/tacky window? No offence but I really dislike cases with window's or any kind of flashy lights.
joxang how much did that water-coolng setup cost? thinking about setting one up [retty similiar but with the new mayhem pastel green
Sorry didn't see this. The WC stuff probably cost around £350-400. Watercooling is bloody expensive :(.
Damn right it is :( im not going for a full loop for quite a while now
Do you think it would be beneficial to get a high end air cooler or a H50 corsair water cooler?
I'm using an A70 at the moment and I'm seeing some awesome temps matching those of people using WC such as H50.
The main benefit of WC for me is GPU silence. It's pretty easy nowadays to get a high cpu overclock and silence on high end air, or an H-series cooler. The quietest GPU coolers however are still too noisy, and only WC can give you a totally silent system.
But if cpu clocks are what you really care about then by all means get a good air cooler :).
Its not what i care about most but its all i can afford :(
You can also get closed loop coolers for your gpu (check out CoolIT's stuff) and if you don't mind doing a bit of modding, you can turn most of the H-series coolers into GPU-only water coolers. I believe the H50 is pretty popular for that, google it.
Swap out the fans for a couple of Scythe GTs or noiseblockers and you can have a nice silent GPU cooling system for a fraction of the price :-).
Swapped out the window and I stuck 4 x Xigmatek White LED fans on the Side Mesh.
Looks good and makes the cooling even more impressive :)
There silent on the lowest RPM, when you go at 100% with them there louder but not much louder. I always have mine on 100% and they are still pretty quiet.
I got mine this weekend, it was so nice to build in. Have to admit having it running I don't find they are completely silent, but then I do have it sitting about 2ft from my ears at the moment on a set of drawers. Still quite quiet, but was wondering if anyone has any recommendations for fans that run closer to silent?
I built a new PC recently for a friend and he chose this case... it really is one of the best looking cases out there imo. Cable management is unbelievably good too. Everything apart from the PSU/Mobo is tool-less install.
I have an Antec P182 and I'm very tempted by this case, the only thing putting me off it the noise. They aren't hugely loud, especially with the fan controller. If I could get some quieter fans then this would make a great case even better!
I think I have one of these coming christmas day :D Along with a new white desk that I already have :p. Not to sure tho but I caught it in my mums tabs.
