12 Mar 2013 at 13:30 #1 rabc1690 rabc1690 Permabanned Joined 29 Jan 2013 Posts 317 does anyone know if a 240mm rad will fit in the front of the 600t without and case modding at all??
12 Mar 2013 at 18:33 #2 Alex h Alex h Soldato Joined 13 Jun 2009 Posts 6,065 Location In the asylum don't thimk it will
12 Mar 2013 at 18:51 #3 pgi947 pgi947 Soldato Joined 25 Jun 2011 Posts 16,800 Location Aberdeen I wouldn't think so, you'd need to cut into the optical bays. A 200mm rad should fit just fine though.
15 Mar 2013 at 17:25 #4 Chrisbes Chrisbes Associate Joined 19 Apr 2010 Posts 393 A thin 240mm will fit in the top such as an XSPC EX240 (http://www.overclockers.co.uk/showproduct.php?prodid=WC-084-XS) In the front you can fit a Phobya 200mm Radiator
16 Mar 2013 at 23:07 #5 RichH RichH Associate Joined 1 Dec 2011 Posts 434 You can also fit a 360 in the top with very limited modding.
