Corsair 600T
14 Nov 2012
Chesterfield
I have a Corsair 600T with a mesh & perspex windowed panel. I've got the parts for modding the mesh panel to incorporate a larger perspex window, but I'm not sure where to get the trim from.
Any idea where to get the trim for this project?
You could try a search for "car edge trim moulding" off a popular auctioning website. I'm pretty sure OCUK don't sell it
Although you might have already purchased it, have you checked out the replacement perspex side panel mod for the 600t.
There are a few places you can buy this pre-done you just add your own latches from the original panel.
Here is an example of it.
I have seen the perspex panel and it look amazing but at over £100 inc P&P, it's a little steep.
Could someone recommend a thickness for a perspex window? Would 3mm be too thick? I'm modding my side panel to house a bigger window.
