Got one of these this morning after my Enermax died in a puff of smoke yesterday (just what I need with the amount of uni work I have to do for tomorrow)
Got it running the system in my sig (Q6600 @ 3.6). Fairly steady load using 3dsmax, and the psu itself is quite hot. Yet the span is spinning very slow, can't feel much heat coming off of the back though. The top of the psu is hot to the touch, not hot enough to be uncomfortable on the palm of your hand, but hotter than I'd like it to be after my Enermax died yesterday and was also very hot :s
Also one of the PCIe cables that came with it doesn't fit into the powersupply properly, the clip on it is too wide to go in :s
Luckily the Enermax ones work fine.
