Corsair 6400 C5 Memory Query (XMS)
20 Aug 2006
First RAM I've owned where higher voltage = less stable ...is this common for Corsairs
example, my E6600 running at 2.95 gig 4:5 ratio
memory is at about 825 MHz so not a big overclock for the RAM at all
1.95V = Orthos runs for 3 mins before failing
2.0V = Orthos lasts for 20 seconds before failing
1.9V = stable !
Any ideas ? I've never owned RAM that doesn't like volts ..
thanks, Mark.
could be - case is well ventilated though with 3x120mm fans ...
Wouldn't heat build up though ?
825 @ 1.95V = 2 mins Orthos stable
now tried 835 @ 1.90V = Orthos stable = over 20 minutes
surely 20 mins @ 1.9V would build up more heat than 2 mins of 825 @ 1.95 ?
