Corsair 650D questions
And
And
7 Dec 2002
>500m
Thinking of buying the Corsair 650D. I'm using a Corsair HX650W psu, will the cables that came with it be long enough in this case?
Also, the power switch etc cables - seeing as the power switch is at the top of the case, are these cables slightly longer to reach the bottom edge of a motherboard?
I was originally going to wait for the 900D but in all honesty it's overkill (as is the 800D), but I'm wary of the (possible) need for extension cables.
cheers
and
Hi mate im using a HX750w which afaik has the same cable length and im also using a Define XL R2 which is a full tower case, the power cables are long enough to reach the top of the motherboard :)
as for the front panels, they are design to reach the bottom of the motherboard :)
