Corsair 7000d airflow
11 Jul 2003
Telford//west mids
I'm looking to buy this case but I've got a few questions if anyone has one.
How good are the stock air filters at keeping dust out.
Are there any problems with psu cables reaching the motherboard cpu power connector.
I’ve got the 7000D and it’s great, it’s silly heavy though when fully loaded up, I needed to buy a new table as it was creaking under load!
The filters are good though and there’s no issues with power supply cables reaching the top of the case etc.
I've got the 5000D.. I love it.. but honestly, I'm shocked as to how much dust the filters have collected already. And by no means am I slack on my house cleaning..
I had to replace some faulty fans the other day, and I think the filtration should be finer as there is a fine layer of particle dust inside the machine already..
Half tempted to get a Dyson HEPA filter and have that running in the background. :cry:
I saw some hand held device on YouTube that blows the dust out of your pc so I'm going to look into getting that.
I have a hand blower but I never needed it when I fitted demcflex filters,I'll probably buy one for the front and top.
Great filters as I've got a set for my phantek evolv x and they stop a fair bit of dust compared to the stock ones.
Ocuk sell Black ones but I'm not sure if I just need a 420mm rad filter as I don't have the case as it arrives later on today, but if you measure the sock ones on the case to the ones the shop sells it may fit.
