Corsair 700D Side Window?
6 Jun 2009
London
Hey guys,
Planning on buying a 700D but I would really like to have a the windowed side panel.Do you guys have any ideas from where I could get one?
I already tried Corsair Store and also contacted them but they don't have an ETA on alternate parts.
Thanks in advance.
Someone was trying to get a hold of a non-windowed side panel for their 800d http://forums.overclockers.co.uk/showthread.php?t=18195070
best advice
Either contact Corsair direct, or ask OCUK nicely, they might be able to get one for you.
Alternatively, if you don't want the windowed panel, get on the MM and see if you can find someone with a 700d who wants a window and will swap.
So since you already contacted Corsair, might want to ask OCUK or check MM maybe the same person is still looking to swap?
Or you could just mod your side panel... since imo the 800d's window is a bit too long dont really want to show off your PSU do you?
Note: You probably already know that a 800d (windowed side panel) can fit on your 700d (which is not windowed)
Well then I suppose I will try to ask OCUK if they can get one for me.Otherwise I will ship the side panel over to a modding company.
I would say modding is cheaper & you get what you want
Hello mate, Do you mean getting a company to custom cut or doing it yourself?
If you mean getting a company to custom cut a side window, Mind sending me a link that would do a window panel for the 700d same design as the 800d but would stop at the 'shelf' above the PSU section in trust(As per OCUK rules) as i cannot find anywhere.
As the 700d is far cheaper than 800d and as i would never use the hot swappable bays it seems like the perfect plan
I thought about sending the side panel of the 700D to a modding company to cut the window but when I think of it....it would cost me about the same amount of money for the 700D+modded side panel as I would pay for the 800D...maybe 10 quid less....
But your still stuck with that standard window that goes all the way down past the PSU section, But if you like that, i guess it isnt a problem
