Corsair 750D and EK Predator 360 is there space
22 Aug 2009
I'm thinking of replacing my Corsair 800D with a 750D airflow to put a couple of loops in.
I have an EK Predator 360 for the top, just wondered if there was sufficient room in the top for this and would appreciate any advice.
Regards
Fred
i have a 54mm height rad inc fans in my 750 and im sure there was plenty of room left , i also think you can offset the rad to the near edge of the case but you would have to put your cd drive in the lowest 5 1/4 slot.
if no one else replies i'll measure it up tonight as i have just finished my rig, also got a 60mm thick EK CoolStream XE 240mm Radiator in the front.
