Corsair 750D fan configuration question
Der
Der
12 Jun 2012
Hi guys. I have a question regarding 750D, I have tried to find the answer but unfortunately could not.
Basically there are two HDD cages at the bottom of the case. There are also 2 slots for 120mm fans below them. Is it possible to move the cages somewhere to the top, i.e. below the DVD drive for example so I can have the best of both words - the fans AND the HDD cage? I only have one 3.5 HDD and was planning to have two intake fans at the bottom hence the question.
if you look at the dvd cage, there is a set of slots uder the dvd bit that the hd cages can slide into.
You can fit either one, or two, as they can slide into each other. They then hang there above the floor, leaving loads of space for fans etc
Take one out and have a play. you'll see what I mean ;)
Thanks a lot :) Ha ha ha, I have not bought the case yet, that is why I am asking :) That was one of the things I wanted to check before purchase :)
yeah well the hd cages go either side by side on the bottom, or hang under the dvd slots. google it. i'm sure you'll see pics.
all the cages are designed to fit into each other.
