Corsair 750D, Water Cooled, Project "Golden Night" [IN PROGRESS]
25 Apr 2014
Denmark
Corsair 750D, Water Cooled, Project "Golden Night" [Done]
Hey Awesome people, this is my first ever build log and watercooled system, also first time i try modding and sleeving :)
I have now started building my "Golden Night" machine..
It's gonna be a Water cooled Corsair 750D with colour theme "black/gold"
This is my first ever watercooled build, so i'm very excited to get started with it
Here's a list of what i have so far for the build:
Hardware:
Case: Corsair Obsidian Series 750D
CPU: Intel Core I7 4770K 3.5GHZ 8MB Haswell
GPU: 2 x EVGA GeForce GTX 680 2048MB GDDR5
PSU: Corsair RM Series RM850 850W
Ram: Avexir Core Series GOLD - DDR3-1600, CL9 - 16 GB Kit
MOBO: ASUS Z87-PRO LGA 1150 Intel Z87
OS SSD: Samsung 840 EVO 120 GB
Backup SSD: Samsung 840 EVO 1000GB
Water cooling parts:
CPU: EK-Supremacy Clean CSQ - Acetal
GPU: 2 x EK-FC680 GTX+ - Acetal
GPU Backplate: 2 x EK-FC680 GTX Backplate CSQ - I Am thinking of getting Custom backplates in black, with Nvidia Claw in gold, and gold writing "GTX 680" (work in progress)
Reservoir: EK-RES X3 250ml
Reservoir Top: EK-RES X3 - Multiport TOP
Pump: EK-D5 Vario X-TOP incl. Pump
Rads: Magicool Slim Profile 2X140mm + XSPC EX360 3x120mm
Fittings:
Monsoon Adapter 45 Grad 19/13mm - gold
Monsoon Adapter 45 Grad 19/13mm - black
Monsoon Adapter 90 Grad 19/13mm - gold
Monsoon Adapter 90 Grad 19/13mm - black
Monsoon Push On fitting 19/13mm - black
Monsoon Push On fitting 19/13mm - gold
Monsoon Light Port 45° Rotary Angle Fitting - black - for temperatur sensor
Monsoon Premium G 1/4 Temperatur Sensor - gold
Monsoon Standard Rotary Color Accent Disks - gold
Monsoon Standard Rotary Color Accent Disks - black
Modding:
Bitspower D5 / MCP655 Mod Kit - Gold Finish
2 x 12" cold catodes in yellow, with black sleeved cables
4 x BitFenix 6-Pin PCIe extension cable - sleeved Gold/Black
6 x BitFenix 3-Pin PCIe extension cable - sleeved Gold/Black
1 x BitFenix 24-Pin ATX extension cable - sleeved Gold/Black
2 x BitFenix SATA 3 extension cable - sleeved Gold/Black
Fans:
3 x Corsair Air Series AF120 Quiet Edition High Airflow 120mm Fan
3 x Corsair Air Series AF140 Quiet Edition High Airflow 140mm Fan
3 x Corsair Air Series SP120 Performance Edition High Airflow 120mm Fan
Lamptron FC Touch Fan Controller
<3<3<3<3 The build is now DONE <3<3<3<3
Here's the first part of images from the build process:
Rest of images are below in a post :)
Hope u like it, please comment,
Thx guys,, The build is now complete <3<3
i will upload SCHRINKED images very soon :)
if you have any questions about my thought process during the build, please ask away and ill do the best i can to answer :)
I had 1 leak from reservoir to the pump, tried 3 times to fix it, but ended up using the old res top with single hole, as the buttom instead, wich fixed the leak :) ..
i made 2 acryllic plates, covered 1 side of it with carbon foil and put one in the buttom of the case, as a mirror wic reflects all the gold <3<3,
and the other plate i put in the back to cover up the SSD's :)
Looks great,,
Idle temps
CPU 27 Degrees
GPU 25 Degrees
Load temps
CPU 45 Degrees
GPU 40 Degrees
<3
Images of the final build stage and end result
Here's the final part of images from build process + Images of the FINISHED BUILD <3<3<3<3
Hope you like it <3<3
Really like the black and gold extremely nice build. Can I ask what type of paint you used on the fan rings? Did u prep them or just straight paint?
thx very much man :) ..
http://imageshack.com/a/img843/1739/wb2hk.jpg
theres an image of the paint i used..
i tried painting a few without doing any prep work on them,
and few days later still looked awesome and paint didnt peel off in flakes.
so prep work sandpaper is an option, but i didnt do it :)
Love it black and gold!
So pleased u got the gold pump kit!
Did u get it from the states?
yeah, just HAD to get it ! :D .. but normally u have to get the bitspower mod pump top thing also... but i just think the ek top is so much nicer looking..
so i went with that and just made few modifications to make it stick :D
got it from performance-pcs.com i think
just messed a little with the OC,
currently at 4,4GHz with 1,25v with max temp of 76 degrees on 100% load..
idle temp at around 32 degrees..
Is that good/safe temps ??
