corsair 760t
30 Dec 2010
hi
i have a corsair 760t that im looking to fit water cooling too. just want some advice be for i buy more parts.
i have 2x 670gtx 2gb cards with heal killer water blocks
i5 2500k cpu hopefully going to get a xspc cooling block
xspc 750 bay res/pump.
looking at the radiators i can fit in the case. i was originally planing on a 240mm monstra in the front push + pull fans. would getting the 280mm one make much difference?
in the top of the case i was going to fit a 360 rad but have since decided that i want to keep the dvd drive so looking like 280mm is the biggest i can fit. unless someone else has fitted a 360 with the drive bay fitted?
so basically will 2 x 240 rad be enough to keep this cool? or would 2 x 280 be much better?
I have a 760T, first thing I decided when buying WC parts was to get an external DVD drive and free up some room. Can fit a 360mm rad in the top and have a fan controller in the top bay drive slot easily enough still.
I went for an NZXT Sentry Mix 2
http://www.overclockers.co.uk/showproduct.php?prodid=BB-002-NX&groupid=701&catid=2331&subcat=189
Wanted something which could run the 2 front fans as well as the 3 fans on the rad and control the D5 Pump. Plus I didnt want anything with a screen so this was pretty perfect. Think I picked it up on offer for £20.
crap quality pic but I think its nice and subtle!
