- 21 Mar 2013
- Stockton on Tees
Hello I have 2 questions:
1. Will this fit onto a Corsair 780T Case? I need a few of them
https://www.overclockers.co.uk/silv...-bp-pci-slot-covers-black-matt-ca-187-sv.html
2. I am also looking for a RGB LED kit where I can change the colours with a manual control (I think they use infrared) I have 2x50cm green LED strips installed which use this connection:
Does OCUK sell a LED RGB kit that will just fit onto that connection?
Thank you
Thank you
