Corsair 800D How To Remove The side Panels?
15 Jun 2003
Darlington
I pressume that you press the buttons on the rear & pull the side panels to the rear of the case?
I was going to read the instructions but they are inside the case :(
Still wont budge :(
There seems to be no where to grab the panel to pull it.
Done it :)
lol this thread made me smile ;)
Are you air or water cooled and if air let us know what temps and fan config you have, this case looks very nice but im reading it has air cooling issues
Pull off the front panel first, if its new they somtimes stick a bit.
If you pull too hard on the panel you will warp it.
To remove the front panel pull sharply at the bottom near the base of the case.
Cheers
Cheers
Thats what i did in the end :)
It was well and truly stuck,but seems fine now.
