 - 24 Aug 2007
I bought the 900D around six months ago to house a dual radiator and my watercooled PC
I’ve now decided to sell it and purchase the Caseland SMA8 and these are my reasons (for anyone considering the 900D)
The quality of the case is relatively poor given the high price tag. It’s easily misshaped when you are tipping the case back to front and side to side when bleeding your system. You can tell when it’s been bent slightly out of shape, as the side bay door on the bottom window side won’t close properly and is misaligned
The plastic hard drive trays are very poor quality and literally will fall apart in your hand, and you have to put the pin back through and place carefully in the drive bay
SSDs are no problem, but normal HDDs (even Green ones) rattle like crazy and produce a very noticeable audible hum and vibration, which is sometimes so bad we can hear it from our living room (PC in conservatory). The hard drive is fitted correctly, and slid in all the way.
Another issue with it being slightly misshapen, is that the side window panel won’t quite close properly.
I also found the space around the back of the motherboard tray inadequate for multiple cable extensions, something that had been highlighted on other youtube reviews of the case – the SMA8 has tons of room from what I have seen.
Top radiator mount cannot properly fit an Alphacool Monsta 80mm radiator with a single fan, it’s so tight on my rampage extreme iv CPU power connector, that it’s damaged the cable – I would say a 60mm should be OK
All in all, not at all impressed for a £300 case – but it’s probably OK for a standard air cooled PC where it’s not going to be getting moved or tipped from side to side to bleed etc
 previously I've had a 800d and that was solid but not large enough and a Switch 810 which was alright but just felt a bit cheap. And I went for the white one which I quickly got bored of. It currently lives unloved in one of my parents wardrobes
