Corsair A50 - PUSH / PULL
Caporegime
8 Sep 2006
On Ocuk
I know that the A50 is only a 1 fan cooler but has anyone modified one to add two fans?, I was thinking of using an elastic band and attaching a second 120mm fan pull on the other side. :D
Loads of people have done it, including myself a few years back.
Just remove 2 of the scews from the other side and use them, much easier than faffinf about with bands/ordering new screws.
or you could use zipties, thats what i did to get two fans on my Titan fenrir last year :D not pretty but knocked a fair bit of load temps :D
