Corsair A50 Temprture problems please help
12 Oct 2009
Corsair A50 Temperature problems please help
Hi i have a Corsair A50 cooler cooling my I7 950 overclocked at 4ghz 1.3 v vcore
the problem is im getting 48-49c on idle and 90c on full load every other person reports much better temps than that i have reseated the cooler and applyed tim 3 times now using artic silver 5 i also have a pull push configuration with 2
Scythe Kaze Jyuni 1900RPM Slip Stream fans what am i doing wrong please help :(
What is the arrangement inside your case? Are you pulling air from outside the case or are you pushing air from inside the case out? Is there enough air circulation within your case?
I've got both the H50 and H70 and my temps are around 32 to 35 on idle and around 65 to 68 at 100% load
Hi thanks for your responce i have a Coolermaster CM-690 II Advanced Dominator Case 140mm fan intake on the front 120mm on the bottom pushing air inwards and 120mm fan on the roof blowing out and the A50s fans on the rear blowing outwards i have tried them blowing inwards and outwards no change in temps
