Corsair AF120
They will work best with no airflow restrictions, so if they are behind any hard drive cages then you might be better with sp120 for the front.
*edit.
Little bit of forum stalking going to assume you've got the Corsair air540.
in that case here are your fan mounting options.
Cooling Front 2x 140mm intake fan (supports 3x 120mm)
Rear 1x 140mm exhaust fan (supports 120mm)
Top 2x 140mm/120mm fan mounts
AF fans will be perfect as the air 540 dosen't have any restrictions at the front. however completely upto you if you want to go with dual 240s or triple 120s.
However personally I go with SP fans all over so I'm not restricted if I decide to change things around in the case. Generally they will create higher airflow velocity which will help to get cooler air in quicker and hot air out faster. Also helps when pushing air into the graphics card intakes.
